AlexStromberg
Epic gamer
- 10:16 AM
- Apr 12, 2022
- Sweden
Bought my first stihl. Will buy 044 HD filter base and 038M cylinder to make it a ripper
Yeah but finding bigger saws here is such a pain. 13" bars is the standard bar. So finding anything bigger than 50cc is hard.Welcome to the forum.
The QS models are not overly desired over here. Good luck with your build.
Yes. Might not be genuine Stihl, but there are .325 rims that fit standard spline hubsDoes anyone know if there is a .325 drive rim sprocket that will fit an 044 clutch drum?
Would you happen to have some direction, possibly a link? I have searched quite a few venues and not been able to locate anythingYes. Might not be genuine Stihl, but there are .325 rims that fit standard spline hubs
Try cutting 2 or 3turns out of the metering lever spring. Ii modified an ms 250 carb for my 180 and it's a screamerSomebody dropped off a 170 that refuses to accelerate off idle. What is a good baseline setting for the "L" jet?
Mark
If you go to Ebay or Amazon and search .325 standard spline rim you'll get some results. Seems like just 9 pins showing up.Would you happen to have some direction, possibly a link? I have searched quite a few venues and not been able to locate anything
,but not sure if its possible to reverse it?
Cause I like to party. I never did the upgrade on my 036. It's ported and pretty sporty and I haven't had any failures yet.Possible with the right bearing and drum, but not advisable due to the failures that necessitated the upgrade in the first place.
Why convert an 044 to .325 anyway?
Is the 038 mag cylinder a direct bolt on or little moding to make it fit?Bought my first stihl. Will buy 044 HD filter base and 038M cylinder to make it a ripper
What is QS? Never heard of thatWelcome to the forum.
