old_sir_henry
- 8:10 PM
- Nov 9, 2018
Do you have a way to pressure and vacuum test? I think I would start there, so you don’t accidentally burn it up.6100 troubles!!!
I bought my 6100 new this year (it's a 2012 model though). I may have ran 3 tanks through her so far, but here is the deal. I tried to tune her a million times by now because at full throttle there is a small delay. Thought this might be the reeds that have to loosen up over time, but then I found out that adjusting the H screw that the delay becomes much greater when I turn it in. So it doesn't get enough fuel I thought. Turned the H screw way out and it is better now, but there is still a small hickup when I rev it.
Looked up the factory settings and it should be L 2 1/2 turns out and H 1 1/2 turns out.
I have the L at about 2 1/2 but my H is 3 turns out!!! Turn it in any more and it looks like it's getting to much air and not enough fuel. I can turn the H screw out further, but it doesn't matter how far I turn it out, I can't seem to get it to fourstroke in the cut. Thought there might be an air leak somewhere, but the saw is brand spanking new. Tune all my saws myself, even other people's saws. This is the first stratified engine i've done though.
Is it the carb or am I looking in the wrong direction here? I really want this saw to work perfectly, because it should become my go to worksaw along with my ps420.
Any help would be much appreciated.
Does it idle normally? Even if you turn it on its side?
Is there any way you can post a video of it?It does idle correctly on al sides. It's just curious that the H is turned out 3 times and still doesn't fourstroke all the time in the cut
If the saw is built 2012 then chances are, it still has the old style intake hose.
This part has been altered by the factory because it was known to cause trouble
tuning the saw.
Damn surprised you know of the Kennedy tunnel in Antwerp Andrew! Most famous for it's traffic jams. But I have to agree on that Ferrari thing you mention though.
I was just wondering on what other people's opinion would be on the design performance wise. The welding doesn't look that pretty I admit, but I should not comment on somebody else his welding, since I'm not a welder myself.
I felt like my 9010 was underpowered due to the muffler. Tried to mod it, but ended up trashing the muffler instead (please no comments on that). My cheap ass didn't want to buy a new muffler, since I could swap out my other 9010's muffler.
Then I saw BBR's video on the 9000 with that crazy muffler and thought why not?
Just wanted to hear some oponions before I make something like that.
Interesting what was wrong with the old intake hose?
On a stock muffler you can drill into the baffle and make the holes bigger without
Splitting it
Spent plenty of time in that traffic jam before the crash barriers went up and after and also when they put the speed limit down
there’s no alternative realy to going through the tunnel when you need to go north and east
You could take the liefkenshoektunnel and avoid the ring entirely. You would have to pay though.
With an hour of swearing and a carbide burr...I was just wondering on what other people's opinion would be on the design performance wise. The welding doesn't look that pretty I admit, but I should not comment on somebody else his welding, since I'm not a welder myself.
