POULAN The Official Poulan Thread
Cut4fun
Redneck Chainsaw Repair
12:42 PM
Ohio
Cool! I have not seen that decal. All of the Poulan's and Re-branded Craftsman's that I have come along don't have.
Roger gets a better pic of the saw I sent him. Maybe we can make out what it says.
Wasnt important to me back then to even take a pic.
fossil
12:42 PM
Ontario, Canada
Once upon a time (at least up to the early '80's and until???) UL stuff was not accepted in Canada and required a CSA approval and vice versa.
Now both organizations' standards are generally accepted by both countries.
Z62.1 is for anti kick back stuff and Z62.3 pertains to chainsaw design. It's hard to get the full reg as all these organizations sell copies at pretty high prices.
Duke Thieroff
Fill your hands you SOB!
12:42 PM
Beaver County, PA
ChipsFlyin
OPE Platinum Member
12:42 PM
Pittsburgh
Yep!
I'm the guy developing this setup, if anyone has any questions I'd be happy to oblige.
It's great to see some of the 3400 and 3700's can be resurrected as a 4000 down the road! They may not be the fastest saws in the world but are definitely bulletproof torque monsters. I grew up with the Craftsman version of the 3400 and know it never needed anything other than the regular wear and tear stuff.
countryhog
BTDT
11:42 AM
NW Arkansas
Got a leaky cap on my 3.7. Just wondering if a gasket cut from innertube would last?
Course i could tighten it down until i either could never get it off or i busted the filler neck. Guessing that why so manyfiller necks are cracked. Or i could just run it with a small leak. Would keep a body from storing the saw with a half or full tank
legdelimber
12:42 PM
N.C.
countryhog. About using an inner tube to makea fuel gasket?
Personally.... I've never had any luck with using inner tube material in contact with gasoline and oil. It always swelled up and went sorta mushy (especially so with gasoline). Then it just popped out from between whatever things it was supposed to stop the fuel from getting out of.
So I quit trying to use it, some years ago.
Now with my having said all that, maybe modern tubes could be made from something that will work now?
I just wouldn't get my hopes up, is all.
countryhog
BTDT
11:42 AM
NW Arkansas
Looks like nitrile (buna-n) may be the way to go. Cant seem to find any sheets of it. Anyone?
Cut4fun
12:42 PM
Ohio
S Sidwell
12:42 PM
Georgia
Cut4fun
12:42 PM
Ohio
I think thats the seal that goes around the tank neck at the starter cover.
Steve on Tapatalk
Yep that is what I clicked this morning. I dont even have one to check now.
So is it just a 0-ring like stated in IPL?
Kit - Oil and Fuel Cap No Longer Available [ More Info ]
Part Number: 952010438
Discontinued
Note: Includes O-Rings
12:42 PM
In addition to McMaster -Carr often times buna-n sheets can be found on flea bay . This is 12" by 12" by 1/8" thick I bought to make a gasket to repair an 8 HP Briggs engine that blew a rod through the end of the block .It's an old trick using sheet aluminum with a gasket that's been done for years ,most people never even heard of it .It works .
