POULAN The Official Poulan Thread
e.fisher26
11:01 PM
Ma, USA
Have a 25 and a 110 in pieces right now, so fun times ahead!
So heres my Poulan. One of them. Grey and black 3400. Going to a new home soon with a guy I work with. Noticing it smokes a wee bit more than it should, and I'm seeing a little oil stain on the muffler. Assuming it has an impulse oiler, since it oils while it idles.
Is there a check valve or any likely culprit I should look for? Dont want to send it down the road not right.View attachment 172117 View attachment 172118
Might be a simple carb adjust
Husqvarna st230p
Craftsman 3.7 chainsaw (2)
Craftsman yt3000 mower
Dream
11:01 PM
Elberton, GA
Button is on the top front of the top handle. Push rod runs down behind the flywheel.
Dream
11:01 PM
Elberton, GA
Got the parts saw. Have to work at the OTHER job for awhile to pay for more "parts saws". More on this later.0321191436.jpg
S Sidwell
11:01 PM
Georgia
Button that's supposed to be with the diaphragm.
Steve, Samsung On5 using Tapatalk
Dream
11:01 PM
Elberton, GA
Have no idea where the button or diaphragm are. Only thing inside the pump diaphragm housing was the spring and a bunch of crud. No idea who or more importantly why took it out. Just know it dont work well without it.
What part of GA? I'm in Northeast part.
S Sidwell
11:01 PM
Georgia
Bostwick-Morgan Co, between Monroe-Walton Co, and Madison-Morgan Co, and 15 minutes from Athens.
Dream
11:01 PM
Elberton, GA
Yep. Grew up in Madison co near Ila. Elbert co last 25 years. Come thru Monroe a lot. Brother is buried at Hill haven on 138. Have to visit ever now and then. Also go to Conyers for work some. Got to keep thread on track, so head down 72 to Comer if you want used Poulan parts.
S Sidwell
11:01 PM
Georgia
Just looked at my diagram, forgot the button plunger was part of the diaphragm. Must have busted so they pulled it out, I imagine they plugged off the impulse hole also.
S Sidwell
11:01 PM
Georgia
I may do that if I need anything. I used to work in Monroe til Horton Cadillac closed, then moved on down to Jimmy Britt Chevrolet. Horton was closer to home thats for sure, less than 30 minute ride instead of an 50 to 60 minutes now.
S Sidwell
11:01 PM
Georgia
You need a manual on the s25da?
Dream
11:01 PM
Elberton, GA
That would be awesome if you have one.
No, the impulse hole was wide open. Looked like they tried to run it a good bit, judging from the crud all over everything in there.
S Sidwell
11:01 PM
Georgia
I'll send it to you tomorrow morning when I'm at the shop, faster network.
old_sir_henry
5:01 AM
The S25 is running.
Took a while to have it suction fuel from tank into carb but finally it runs.
Since the chain brake seems to be a rare part, I'd like to show you a design-flaw
it comes with:
The chain brake housing is too week so when the lever powered by the brake's spring knocks on it once you engage the break and it will crack the housing sooner or later.
JDlowe
Sawmaster
10:01 PM
Joplin
Here is my Poulan Model B saw, missing the cylinder cover and rewind, if anyone knows where those parts are for sale or tradetI would appreciate it. Very neat early Sand cast magnesium saw.
Dream
11:01 PM
Elberton, GA
That is a sweet saw JD.
Cant really tell from the pics, was it originally the tan color?
Got a little tear down done on my parts donor S25DA. Was expecting to get a good oil pump diaphragm. No dice. This one was badly deteriorated. Pump rod and button completely separated from rubber diaphragm. At least it was there. Dad says he has a poulan there that he couldnt get to run. I may pick it up when I go visit this weekend and see if its any good. Parts saw was seized. Got it loose, but the plating is gone. Will save the piston, rod, etc. Rest of the saw isnt too bad. 0327192013.jpg 0327192013a.jpg
S Sidwell
11:01 PM
Georgia
Well at least it Had one.
Dream
11:01 PM
Elberton, GA
Getting better every time Steve. Maybe the next one will actually be in one piece!
S Sidwell
11:01 PM
Georgia
[emoji23] LOL
