POULAN The Official Poulan Thread
countryhog
BTDT
1:38 AM
NW Arkansas
Got that peckerwood running a while ago. Got to thinking it wasn't getting fuel. Realized I had cleaned everything EXCEPT the port from the fuel tank to the carb chamber. Took the carb line off and sure nuff couldn't even blow air through the port. Had to use a punch and piece of coat hanger wire to push whatever it was back into the fuel line. Blew it back out the other end with compressed air; after I removed the filter. Dang I'm glad that's solved. Now to see how it actually runs. Dumpster saws!Whaddayagonnado? But more ofcourse. Y'all pay attention now ya hear
countryhog
BTDT
1:38 AM
NW Arkansas
Anyone got a complete clutch cover for a 306A? Someone in the past tightened the bar nuts down without seating the cover. Result - 4 cracks; foot is gone too though that mayve been a separate issue. Got lots of Poulan stuff to trade
67L36Driver
1:38 AM
Happens frequently on them Jerry. Getting scarce they are.
Toad22t
1:38 AM
Central Wisconsin
I am looking for some info on a saw that I will be posting for sale. I believe I believe it is the equivalent to a poulan micro, but not quite sure. It's a Western Auto wizard 010! Here is some pic's. IMG_20160907_165804.jpg IMG_20160907_165838.jpg IMG_20160907_165851.jpg
67L36Driver
1:38 AM
I have a Craftsman in gray/black. 3700, 3800?
Has a bunch of crank end play. .039" Yikes!
They have ball or roller bearings?
paragonbuilder
2:38 AM
Norwich, CT
My buddy picked up this 3400 at the scrap yard for $10.
It needs fuel and vent lines, fuel filter any vent. Anyone have this stuff?
Hoggwood
11:38 PM
Above the 49th
Tygon 0.117 x 0.211 will work. There should be a double-barbed plastic fitting that accepts the external vent line and is friction fit into the tank hole. A green duckbill valve goes on the other end (inside tank). Any generic filter ought to work. Seals are SKF 6119 both sides and a piece of cake to get at and change if you are going that far.
Looks like $10 well spent.
