- 3:35 PM
- Jan 28, 2016
- Dike, Iowa
That's a really nice looking saw!! Glad it's running well too!!Finished up this PM700
That is a nice looking set of gaskets!Just wanted to let people know that I have added the 3-25 and 4-30 gasket set to my eBay.
I'd get it if it was local to meMaybe someone would be interested in this ...View attachment 451742
Set I ordered came in the mail today, looks very well made. I will be using mine along with an adapter w/hose barb on the spark plug hole and the piston at BDC. No drilling for this guy. Thanks for offering up this tooling for others to use and enjoy.I've recently made some plates for checking crankcase leaks. This is for the 10 series saws. You drill for your fitting you want to use. I would like to make some for the bigger saws but need cylinder for exhaust and intake fitment. Is anyone willing to let me borrow one. It can be roached on inside as I only need outside.
https://www.ebay.com/usr/cinci5
https://www.arboristsite.com/threads/mcculloch-chain-saws.71126/post-8378381
So many choices!!Now all I need is a Mac to tear into...
That's a good thing!So many choices!!
Thank you for your kind words. I enjoy making things that will help. I figure in my journey to repair and fix things that anything that worked for me will possibly help others. I will be making the large frame plates, PM800-850 etc. , in the next few weeks hopefully. https://www.ebay.com/usr/cinci5Set I ordered came in the mail today, looks very well made. I will be using mine along with an adapter w/hose barb on the spark plug hole and the piston at BDC. No drilling for this guy. Thanks for offering up this tooling for others to use and enjoy.
Glad to hear you like building them, as there are lots more out there that could be done. Enough a guy could keep as busy as he'd like to be I would venture to say.Thank you for your kind words. I enjoy making things that will help. I figure in my journey to repair and fix things that anything that worked for me will possibly help others. I will be making the large frame plates, PM800-850 etc. , in the next few weeks hopefully. https://www.ebay.com/usr/cinci5
Get some spot putty for the remaining pits. It works great and blends easily or use in place of JB.I have been practicing on cleaning up damage on my McCulloch 200's fan housing. I don't have a media blaster, so I have been using sandpaper and Dremel wheels to get the paint and primer off. Once I find the damage or metal rot areas, I then use a burnishing tool to get out the metal rot and down to good metal. I then fill the recesses with JB Weld and when it is dry, then sand that down. It looks like McCulloch used a tan primer under their paint, unfortunately I only have grey to work with right now. I am using Rustoleum's metal etching primer and it seems to easily cover without having to do too many passes. The top three pictures are before the JB Weld and primer went on. Bottom two are after. Any ideas on cleaning up and buffing the hard rubber spark plug cover?
There are still a couple of blemishes I missed that easily show up with the primer that I will need to address, a couple of small pits and some excess JB Weld that didn't get sanded down.
I have some Bondo Spot Putty, will use that. With the metal rot, I am sure I am not getting 100% out, though after grinding on it I am cleaning it out real good with Acetone before putting the JB Weld down. Wasn't sure which would be better to reduce the rot spread/return, seems like JB weld ends up being harder than the spot putty and that is why I am mostly using this right now. I do have the traditional Bondo with hardener too, but have not used it yet.Get some spot putty for the remaining pits. It works great and blends easily or use in place of JB.
I just meant to use putty for the little ones that were left that's all.I have some Bondo Spot Putty, will use that. With the metal rot, I am sure I am not getting 100% out, though after grinding on it I am cleaning it out real good with Acetone before putting the JB Weld down. Wasn't sure which would be better to reduce the rot spread/return, seems like JB weld ends up being harder than the spot putty and that is why I am mostly using this right now. I do have the traditional Bondo with hardener too, but have not used it yet.
