edju1958
- 5:30 AM
- May 23, 2018
- Western N.Y.
I got the PM 10-10 running today after a lot of monkeying around.First I had to put another module on & the old module didn't want to give up it's plug wire.Usually I can just twist the wire out of the module by hand,on this one I had to use a pliers to twist it out.Then the recoil decided to fall apart.I took it apart completely to find out what was going on.The little bolt that holds the pulley to the spindle was the culprit.I tightened it back up &all was good,but the 3 screws that hold the recoil cover on werretoo easy to loosen,which tells me that someone was into that recoil previously,& that screw may not be the correct one.The other thing that kinda perplexed me was in order for the saw to run I had to turn both lo & hi screws out considerably - 2 1/2 on each.I think I'll need to pull the carb for a cleaning & rebuild.
