Thumper88
- 2:13 PM
- Feb 28, 2020
- Harriman, TN
Nice little truck/trailer setup there...
Wow, how many lbs will she pick up?
Still enjoying your 500?
Did you just do the front spring, or anything else?Much better after swapping the spring and putting a set of 3 points on especially in this bark they’re about perfect.
Still diggin the weight and power? I know I am.Much better after swapping the spring and putting a set of 3 points on especially in this bark they’re about perfect.
Thanks.[mention]CLEARCUT [/mention] here’s some of the parts break downs of the jack rams.
http://www.madsens1.com/sil_jacks.htm
Here’s the back cut of the big girl with a face in her nailed my chain on a hardened over from the second tree being taken off.
Yeah just the front spring, foam piece, and the rubbers for the cases.Did you just do the front spring, or anything else?
My back is liking that more and more everyday I’d be hard pressed to give it up unless the wood really warrantied it. I’m noticing I’m adjusting my grind more aggressive then what I use to run to keep load on the saw.Still diggin the weight and power? I know I am.
So you like it over the 461 & 661 now?
I wonder how it stacks up against a ported 461? I’m sure you’ve had those.
Ut oh...
