redline4
I'm huge in Japan
- 12:09 PM
- Mar 12, 2018
- Rosholt Wisconsin
Yes it is, he should be styling.![]()
I was just pimpin Ryan that he needed a 550 to go with his 572.
Lol Me too.I was just pimpin Ryan that he needed a 550 to go with his 572.
Sure wood like to buy that two fitty fo XP.Here's a few saws to report on and might as we'll start with a woods ported Dolmar 5105 with a reclaimed cylinder and unknown supplied piston. It's running 3/8" chain with a 7-tooth sprocket. Seems to do okay with it though.
A ported Husqvarna 254XP with a 262xp carburetor an HDA-87 if I recall correctly. It's running a .325" cheap-O chain and a 9-pin sprocket. Which I decided to try as it already had a large spline drum on it. Not a bad combo it would seem on the 18" bar. Should sing along with a Prem-O chain I would think. WHich is pretty good for an aging Dinasaur of a saw.
We'll round it out with a 394XP that was woods ported and while it seemed on the surface fairly straightforward a job like any other, wound up being a persnickety problem child of a saw as I've ever came across. Went from the fuel filter plugged tight and the line leaking, to the coil not putting out enough spark to light the fires, onto the main nozzle in the carburetor replaced with a not so easy to find replacement, following up with both side seals being replaced to some goo placed on the NLA intake block as a temporary fix just to be able to run the saw while it was here. A plethora of other parts were installed that were non-essential to the saw running, rather for operational use, too numerous to mention. Truly a Whack-A-Mole kind of deal, which is why it's been nicknamed "The Bastard", it earned it. So this old whooped loggers saw should be good for action once the intake block is replaced, as there really isn't much else that hasn't been fixed. Lastly, as per usual for a saw of this model, she cuts, which makes up for any hardship it gave along its journey to recovery.
That or committed.@Stump Shot you are to be commended for your persistence with the ‘94
@82f100swb I love my ported 3120! You were having too much fun eh?!
Good looking saw there Steve.Here's a favorite of mine, the 572XP
They cut so good, I say 500 my.
They say Lightning never strikes the same place twice, but as far as for doing these 572's, they come out great every time. I am very well pleased to say the least of the outcome of these saws. Which is wonderful for me, as I really enjoy doing them and getting folks into something to make their work more enjoyable.
Especially when $$$ is considered into the mix, which, lets face it, there's not a lot that the 572xp can't do, that the 500i can. With the money saved, a fella can afford to spend an extra second on a cut and not feel too bad about it. Also, you can't even compare it to a 462, it just out muscles them. It's more like a 461 or something like that, it acts like it's bigger than it actually is. Of course, the weight police will be along shortly to remind us that it's heavier than a comparable Stihl model.Even though I'm a Stihl leaning guy, those 572's, and especially the ported ones are a damn fine wood cutting device.
It's a 5 series Husky. So.....Especially when $$$ is considered into the mix, which, lets face it, there's not a lot that the 572xp can't do, that the 500i can. With the money saved, a fella can afford to spend an extra second on a cut and not feel too bad about it. Also, you can't even compare it to a 462, it just out muscles them. It's more like a 461 or something like that, it acts like it's bigger than it actually is. Of course, the weight police will be along shortly to remind us that it's heavier than a comparable Stihl model.![]()
