The Cut Report - After the Bench
Member
11:47 AM
As a firewood only kinda guy, I have not the need for a 90cc saw, however, I have to admire the 592xp, it is one heck of a rig that checks a lot of boxes, runs and cuts great, I can lean on it all I can and it just soaks it up. Its easy to start and stays running once it does, meaning no restart after turning the choke off. Low to no vibration. Did I mention it cuts like hell...
davidwyby
Rural desert logging
9:47 AM
Extreme Southeast CA
You just need 3' dia firewood....
Member
11:47 AM
Haven't had much interesting in a while, well, that changed when finally, I was able to test out this new Stihl 070 that @NightRogue sent me.
While it pales in comparison to the modern saw, I believe that if @mirage can up the sprocket tooth count, she can be an even better cutter, as it has plenty of power left to bear, running about 700 rpm over stock here and still a touch on the fat side for breaking in. I actually had fun working on this 105cc beast I affectionately call Porky Pig because of its all-metal heft. The only thing that didn't go smooth was getting the carburetor to prime without pulling it a thousand times. It took three times squirting mix down the carb throat before it would sustain running. Other than that a few tweaks on the adjustment screws and it was humming along all on its own.
As far as mods go, it got the full treatment, machining, porting, timing, carb, governor and muffler mods. Tried not to get too radical as for one, it'll knock the stuffing out of the bottom end if you get too crazy and for another, it had to be easy to start as well. I think I hit the mark fairly well. These things don't run that fast to begin with.
singinwoodwackr
10:47 AM
moon
Cute little bar :p
I love the sound those old tanks make 😃
Member
11:47 AM
Cute little bar :p
The bar was a source of problem for me, I learned the hard way that one from an 088 won't fit, the adjuster holes are in a different place. When I ordered this one, it was a bar and chain combo deal, and the wrong chain was supplied. Finally, after sourcing another chain that fit, could I run the saw.
singinwoodwackr
10:47 AM
moon
I thought those 3002s fit all the big Stihls
Maintenance Chief
12:47 PM
South Carolina
Was it an open port cylinder?
