The Buckeye Bound MS441
8:41 AM
Awhile back, DDave was looking for someone to go through his ms441 and port it. It needed some new av springs and a half dozen other smalls, as well as a good cleaning and general looking-over.
Upon disassembly, I noticed a small gouge on the intake side where (I believe) at one time, the piston lost a ring locating pin.
He sent a different cylinder to install. This one is more better.
So I reassembled the saw and made a few test cuts for comparison.
Once I had a benchmark, I disassembled the saw and sent the jug to @Miller Mod Saws to have the base turned, as this was before I picked up my lathe.
Here are a couple pics showing the lower transfer layout before porting.
There's not a whole lotta room between the cylinder extension and the case once assembled, so I tapered the extension near each lower transfer port, and widened and lengthened each port. These are roughed in. Not finished
More pics coming
8:41 AM
Exhaust port raised to 99°
Intake port is very close to the edges of the skirts, so i only smoothed it out removing casting flash
I was back into the saw several times, finally setting the upper transfer openings at 124°, for a blowdown figure of 25°.
Strato ports weren't raised or lowered, only cleaned up like the intake.
8:41 AM
Here are some reassembly pics. These are a bit more involved than an 026, 036, 044, 066 etc. Quite a few more pieces. I do like the ability to remove the carb support box
Being able to move the carb box, you don't have to remove the rear handle to attach the impulse line. There's no room to do it from the side like older saws. Also, makes it easy to reattach the fuel line elbow20160607_211112.jpg
Carb box attached
8:41 AM
Intake manifold fits nicely through the hole, with access to all 4 screws
Intake boots installed through carb adapter
After the carb, I attached the throttle cable with needle nose pliers
And then, insert the cable sheath
8:41 AM
Upper spring av
Air filter
And a slightly modded muffler
Dave says this is mainly a gtg saw, and as such, there was no need for a spark arrestor screen on this saw. And if it's a gtg saw, ya may as well be able to hear it
8:41 AM
Graphics in the last video were kinda psychedelic lol. I didn't change anything. Must've been the lighting.
Being a 441 virgin, I asked for some input from others. Special thanks to @Miller Mod Saws, @Mastermind, @Termitebuffet, and @jmssaws for your help along the way
Definitive Dave
Piss Rev Mafia Member
8:41 AM
Central Ohio
NICELY DONE KEVIN!!!
That looks like it picked up 2 or 3 rpms since you got it :)
Does it make me a bad person that I watched the 16" square filed clip first ?
Thanks much for doing this. I use a 441 as half of my two saw plan and loved how smooth the AV and power band were, even though I hear guys badmouth it all the time.
From the video it has a much more usable grunt now and some giddy up and go that they lack in stock form.
8:41 AM
Nah I would have watched the 16" video first too. I've only looked at cut times from starting to ending a cut. In the stock vid, the log was about 2" smaller diameter. I ended up noodling a bunch off that end so I flipped it for a fresh end.
Stock looked to be about 13.5 to 14.5 seconds. Ported was closer to 10 or 11, plus 2" larger diameter in the log.
I've only put 1-1/2 tanks of fuel through it, so it'll gain more when the new rings seat in.
And yes, they are a very smooth saw
CR888
12:41 AM
Australia
The 441 gets a bad wrap sometimes like DD says being heavier than the 440, early strato design, bulky etc. But if you pick up a well ported one or stock and judge the saw based on running characteristics & not numbers on a spec sheet they are very nice smooth good power saws. I like them, really nice to run for hours on end.
