Husky 350
Clint Eatswood
Active OPE Member
11:32 PM
Morgantown
Definitely no air leak. Carb is tuned, both low and high. I decided to pull the jug and measure ring end gap. I'm coming up with 0.021". I'm no expert but this seems to be really high. From what I read on here I should be in the neighborhood of 0.006-0.010". Can somebody provide some insight here? If that's the case, would certainly explain the low compression and poor power.
old guy
Love me some Husqvarna
10:32 PM
Becker Minnesota
As you say should be .006 - .010, .021 is too much. how are you measuring? are you pushing the ring up into the cyl. with the piston to keep it square?
Clint Eatswood
Active OPE Member
11:32 PM
Morgantown
Yes, used the piston to push the ring into the cylinder and measured 3 locations between the roof of the exhaust port and 1/4" from squish band. All 3 measured 0.021".
farminkarman
I like the red & black ones
10:32 PM
Neenah Wisconsin
You need a new ring
Clint Eatswood
Active OPE Member
11:32 PM
Morgantown
Ok, new ring installed with 0.009" end gap. Compression seems suitable. Pops on 2nd or 3rd pull, fires one or two pulls afterward. Low speed screw set and it idles and revs fine, but its running lean up top. I've opened up the high speed screw and can't get it to 4 stoke at all. It also bogs in the cut if leaned into at all. I'm assuming this is a fuel delivery issue and not an air leak, correct?
