Testing 8 9 10pin sprockets on Cannon belly bar, Cannon SBP, Tsumura
Deets066
AKA Deetsey
7:43 AM
Here's a good reason why a rounded belly will have faster chain cutting speed..
See how the raker depth changes and gets taller to accommodate the larger sprocket as they go from flat to rounded:View attachment 41455 View attachment 41456
You'll also notice the angle of the cutters changing.
Doesn't the depth go the opposite way on the other side of the belly
Definitive Dave
Piss Rev Mafia Member
7:43 AM
Central Ohio
$10k to figure out less friction is better? Way to go. :facepalm:
Dude!! I know damn well you can express a difference of opinion in a manner that doesn't come off like all agro for that sake of agro itself.
Julian loves to experiment and adds value and interest to this forum.
If you have ideas to add, even in direct opposition to others posted, try to be half-assed civil.
I have never seen Redbull661 post anything even slightly off-color or untoward in the past.
Seems like he is a deliberate target for you for some reason.
Dave
Definitive Dave
7:43 AM
Central Ohio
dammit now I have to lay a straight edge on both sides, you are an evil man Deets :)
Philbert
Chainsaw Enthusiast
6:43 AM
East Dakota
I can accept why the round belly would be an advantage. The shape also follows the centrifugal path of the chain, as opposed to trying to flatten out the loop in motion. My question is why the incremental change in sprocket diameter / tooth count seems to follow the opposite cutting speed progression on one bar, compared to the other two.
Philbert
Keith Gandy
Maxima K2 40:1 87 Pump Gas
6:43 AM
Provencal, Louisiana
Dave
Whole site has been wacky lately
Definitive Dave
7:43 AM
Central Ohio
Correct me if I am wrong but a saw has torque and the combination of saw, sprocket, bar and chain have cutting speed.
I see people say that such and saw combo doesnt have as much torque as another, but isnt that an inaccurate way of at least phrasing it.
In other words if the same power head bar and chain cut at a different speed with a 8 pin vs a 9 pin the torque didnt change did it?
Maybe I am up too late to think clearly.
When I am trying to find the fastest setup I swap out everything till I get the best combo but I never considered it to have the best torque just the best speed.
Chainsaw Jim
Con Artist LLC
4:43 AM
Springfield Oregon
Philbert
When the rakers are taller there is less resistance on the cutters allowing a larger sprocket to reach max speed in the cut. The rounder the belly the taller the rakers when comparing to a straight belly bar using the same chain.
On a straight bar that same chain ends up with rakers too low for the larger sprockets to keep their speed up so the smaller sprockets end up cutting faster.
Nitroman
3:43 AM
Southwest Alaska
IMHO - the larger the gear/sprocket/wheel the less the torque. So the cannon SBP has a larger "gear"/tip, so it reduces the torque on the cutters coming back towards the saw. Relative, to a smaller "gear"/tip which is on the tsumura.
The other "gear" in the equation ie. the rim sprocket. Which again can also reduce torque by going bigger.
So big gear(10pin) + big gear (wide tip - cannon) = less torque than big gear (10pin) + smaller gear (narrow tip -tsumura).
smaller gear (9pin) + big gear (wide tip -cannon) = basically same torque as big gear (10pin) + smaller gear (narrow tip - tsumura)
that is the way I am seeing it...so far anyway. lol
What!? The only forces your are dealing with are torque and friction (drag). The engine makes the torque and everything else wants to reduce that.
This is EXACTLY why a test fixture is necessary when making these entirely subjective tests. And as long as a human being is touching that saw, it IS subjective. You spent a great deal of time learning essentially, nothing.
Definitive Dave
7:43 AM
Central Ohio
I submit that while a test fixture can tell you which mods to the saw produce the most HP and torque.
Without the other elements in place including wood, you wont know what combo is fastest in the cut.
I want a good accurate dyno like the roses want the rain but it wont eliminate all the testing that goes into finding the fastest setup for a saw.
thomas1
┌∩┐(◣_◢)┌∩┐
7:43 AM
Cristobal Colon
I'm thinking he means a test fixture that will hold and apply a constant load to the saw during the cut, removing the human variable from the equation.
Humans have lots of things that influence the way they perceive information and those perceptions aren't always reality.
redoakneck
7:43 AM
Ohio326
Many factors involved here
Need human element as robotic as possible
Need 100's of cookies to be statistically accurate
Wood needs to be really, really uniform, like a cant??
Thanks redbull, your tests are very interesting, send me that belly when yer done, needs an inspection
Philbert
Chainsaw Enthusiast
6:43 AM
East Dakota
Nothing is free Dave. Torque and speed are a trade off. Think about the gears on a bicycle (at the pedal / crank, since we are talking about drive sprockets), or the transmission in your car or truck.
While the motor (or cyclist) may produce different torque at different speeds, the final torque and speed are a result of gearing.
If speed were 'free' we would all run big sprockets.
Were'nt 2 of the bars 'straight' bars? Did they behave different?
Philbert
