Chainsaw Jim
Con Artist LLC
- 8:58 PM
- Feb 8, 2016
- Springfield Oregon
Wendell's the prick ...T1 is the arsehole......[emoji13]damn dude. you sure are a fckin prick !
Doesn't the depth go the opposite way on the other side of the bellyHere's a good reason why a rounded belly will have faster chain cutting speed..
See how the raker depth changes and gets taller to accommodate the larger sprocket as they go from flat to rounded:View attachment 41455 View attachment 41456
You'll also notice the angle of the cutters changing.
Dude!! I know damn well you can express a difference of opinion in a manner that doesn't come off like all agro for that sake of agro itself.$10k to figure out less friction is better? Way to go.![]()
dammit now I have to lay a straight edge on both sides, you are an evil man DeetsDoesn't the depth go the opposite way on the other side of the belly
I can accept why the round belly would be an advantage. The shape also follows the centrifugal path of the chain, as opposed to trying to flatten out the loop in motion. My question is why the incremental change in sprocket diameter / tooth count seems to follow the opposite cutting speed progression on one bar, compared to the other two.Here's a good reason why a rounded belly will have faster chain cutting speed.
Well I've listened to Physical Graffiti backward is that what you mean?. Does anyone here, actually have ANY background in physics?!?!?
Whole site has been wacky latelyDude!! I know damn well you can express a difference of opinion in a manner that doesn't come off like all agro for that sake of agro itself.
Julian loves to experiment and adds value and interest to this forum.
If you have ideas to add, even in direct opposition to others posted, try to be half-assed civil.
I have never seen Redbull661 post anything even slightly off-color or untoward in the past.
Seems like he is a deliberate target for you for some reason.
Dave
When the rakers are taller there is less resistance on the cutters allowing a larger sprocket to reach max speed in the cut. The rounder the belly the taller the rakers when comparing to a straight belly bar using the same chain.My question is why the incremental change in sprocket diameter / tooth count seems to follow the opposite cutting speed progression on one bar, compared to the other two.
Philbert
So the chain slapping back down on a regular bar causes friction slowing it?10 pin is faster on the belly bar since it's not rising up out of the groove as much like it does on the other bars.
IMHO - the larger the gear/sprocket/wheel the less the torque. So the cannon SBP has a larger "gear"/tip, so it reduces the torque on the cutters coming back towards the saw. Relative, to a smaller "gear"/tip which is on the tsumura.
The other "gear" in the equation ie. the rim sprocket. Which again can also reduce torque by going bigger.
So big gear(10pin) + big gear (wide tip - cannon) = less torque than big gear (10pin) + smaller gear (narrow tip -tsumura).
smaller gear (9pin) + big gear (wide tip -cannon) = basically same torque as big gear (10pin) + smaller gear (narrow tip - tsumura)
that is the way I am seeing it...so far anyway. lol
I submit that while a test fixture can tell you which mods to the saw produce the most HP and torque.
Without the other elements in place including wood, you wont know what combo is fastest in the cut.
I want a good accurate dyno like the roses want the rain but it wont eliminate all the testing that goes into finding the fastest setup for a saw.
Correct me if I am wrong but a saw has torque and the combination of saw, sprocket, bar and chain have cutting speed.
I see people say that such and saw combo doesnt have as much torque as another, but isnt that an inaccurate way of at least phrasing it.
Were'nt 2 of the bars 'straight' bars? Did they behave different?On a straight bar that same chain ends up with rakers too low for the larger sprockets to keep their speed up so the smaller sprockets end up cutting faster.
