Philbert
Chainsaw Enthusiast
- 4:26 AM
- Jan 30, 2016
- East Dakota
Took it to a GTG
Took the FP1000 the Iowa GTG this weekend. Due to the weather, we spent a lot of time inside, and the grinder got a lot of notice. I set it up with some 'practice' chain, and posted my version of the 'Quick Start' guide on the work bench. The grinder was out for more than a day, and I gave a number of 'guided tours', but no one asked to operate it themselves, or to try and sharpen their own chains.
In fairness, the GTG crowd is often more focused on race chain, with lots of 'secret sauce' angles, hand filers, etc. I tried to solicit initial comments (generally positive) before answering any questions, to avoid potentially biasing perspectives on it. And, since I already had the practice chains 'dialed in', I probably made things look easy, as I walked through the Quick Start guide.
We did experience a couple of 'hiccups'. One where the grinding wheel seemed to randomly come down and hack off more of one cutter than all of the others. Maybe the chain hung up slightly when pushed, then jerked forward a bit when released? When using a manual grinder, I pull the chain back against the positioning dog / pawl to positively position each cutter. On the FP1000 the positioning arm retracts before the grinding head lowers. Might have to do with when the clamp grabs the drive link?
A second issue was the grinding head failing to lower occasionally on one loop; happened to be only on Left hand cutters, but not all. These practice chains were worn back to (or close to) their witness marks. Perhaps the proximity sensor read this as 'no cutter', but enough was present to allow the pusher arm to advance the chain?
Just speculating here on both of these. Hopefully @GunTemco can provide some insight.
Philbert.
Philbert.
