Tearing down my JMSSAWS, one by one...
11:37 PM
Hi Bill. Hope all is well.
I've got those. Bought to attempt to weld a chamber. Never got to it.
I gave away all of my pure. And I don't have adjustable waveform-sold my dynasty for this machine. Coulda turned up my EP% and balled the Lanthanated.
The sideways weld is something I didn't think about. Great idea. I've seen guys bend tungsten tips to weld in a tight spot before.
This metal was tinfoil thin. Like in the .005 range at the edges of the weld plug you see, and .001 at the center. I was pretty much ascared I was gonna make his ruined jug unusable if the arc jumped forward at all. Just a second in the wrong place and the metal under the plating would warp or flake.
We contemplated asking/shipping to Shawn, but we agreed in the end to make the attempt and toss the jug if it failed.
I don't tig aluminum that often anymore. I practiced on some .010 roof flashing to get some of my mojo back.
Used 1/16 filler wire and around 60 amps on the pedal. 2% lanthanated 1/16 tungsten.
10:37 PM
View attachment 88761 View attachment 88762
I ain't got no idea what you're talking about, but I nodded along as I read it.
11:37 PM
Sondre, be sure to check out the crankshaft thoroughly in 395 or any of the saws he touched.... The crank in my saw had these weird indents/chips from him splitting the case incorrectly or who knows honestly...Both cranks were garbage in my 394 and 395. Threads were buggered up too on the cranks, sure the saw ran with that crank in it but that's not what I paid or expected in work quality.
11:37 PM
Is there anything on any saw he touched that wasn't gaffed or fubared?
Jeesh. WTF
Like I said in a previous post, I am really starting to think it was all intentional. You just can't screw that much up by accident.
Maybe because he is unable to log any more, no one else is going to either??? There is really something bad going on here. (I remember working for a Sheet Metal company, and equipment was going missing. They found it all in the garage of an employee who used to own his own company but went broke).
Not sure if drugs are involved or not, but I think this goes way beyond just drugs.
srcarr52
11:37 PM
Iowa City
Looks like you did a great job and saved another messed up cylinder.
I've bent pure tungsten and I've chipped sides off of gas cups to weld sideways in a tight bore before. I learned to weld at an automotive machine shop welding cylinder heads, sometimes you'd have to chase a crack half way up an intake port. I bought and still use the Lincoln AC/DC Tig 300 sine wave machine I used there when the shop closed down, it rarely gets put on the Max amp setting anymore.
I use the a 3XXL or 4XXL cup and 1/8" pure tungsten to get down into chambers. Mostly to blend the weld into the chamber from welding up a spark plug hole but I have welded in a chamber to make it smaller before.
I normally use a gas lens and 1/6" 1% lanthanated.
Here is the blended spark plug hole and a little chamber fill of a 046 cylinder. It's really tough trying to add filler to the weld and not your electrode when down in a bore like this. I sometimes have to bend a little hook in the filler tip to reach the tight spots.
srcarr52
11:37 PM
Iowa City
RI Chevy
11:37 PM
earth
Maybe it was a Full Moon when he was sanding the jug Kevin? Could explain the elliptical shapes. Lol
11:37 PM
Very nice work bud.
SOS Ridgerider
Muffler Modded Member
11:37 PM
Central CT
I'll make sure to double check Mason. I didn't see anything like that when I took it apart, though.
