41FanForLife
- 10:19 AM
- Apr 23, 2020
- Don Martin's House
H
How did you modify for higher temps?Before you even get to a grill, I'll go through what I look for in a steak. God only knows how bad I was starting out mainly because I didn't know what to look for.
You'll never go wrong with T-Bone, Porterhouse, striploin, filet migon or ribeye. Make sure your meat is thicker than 1 inch. Thin steaks only dry out and don't let you get a proper sear on the outside and cook the inside to your liking vs thick meat. Buy the highest grade you can.
Pat your steaks dry before seasoning. I season my steaks with salt pepper and garlic right before I fire up the grill.
Charcoal grills are a game changer. Get your grill up to temp before putting the steaks on. I aim for a temp of 500F and up. Whenever I get the chance I use my Charcoal grill to cook with. Get an instant read thermometer. It's the only true way to get your steaks done they way you want without being overdone. Temps change outside, meat thickness changes, variables ya know?
Once there is good grill marks I flip them over only once and cook them to temp. If you want to get fancy you could rotate them 90 degrees to get the cross hatch sear marks, but I don't bother.
Sometimes I let them rest for 5 to 10 mins under aluminum foil, sometimes I don't. Personally I don't see a difference.
Now I'm hungry.
Edit: Forgot pic, yes on my little gas grill, but it's modified so I can get higher temps.
