- 3:49 AM
- Nov 16, 2022
- Long Beach, IN
I have 44.7 oem P&C if interested.
PM sent, please advise details on these
In that case used tranny fluid at 33.666667:1Asking for Nic.
you are the tranny expert…In that case used tranny fluid at 33.666667:1
I thought Ed was the tranny manyou are the tranny expert…
hes into rods and cranks mostly i heard….right @redline4 ?I thought Ed was the tranny man![]()
Looks great.I trimmed the ragged melted front edge of the top cover and cleaned it up a bit.
View attachment 355635 View attachment 355636 View attachment 355637
Instead of trimming the two rear top cylinder fins, anyone else try trimming the inside of the top cover like this guy did?
I had planned to share a compression test picture in this post, hoping for 200 PSI +. I was feeling pretty good about the assembly and how the Motoseal went on, thin coat painted with an acid brush.
Discovered a new problem after the cylinder was torqued down and I rotated the flywheel, could not get to BDC.
It appears the 44.7 mm piston OD interferes with the crankcase ID. This may be unique to my saw, however not sure if anyone else has tried to fit a 44.7 P/C on an 024 AVS.
There is some mismatch at the bore ID in my crankcase halves:
After some consultation with Doc, plan is to relieve case a bit with a die grinder and burr at the 11-1 and 5-7 o'clock positions to enable piston/crankcase clearance. Any other suggestions?
What was the clearance with the other piston? Check that and make it similar it didn't hit anything with that oneThinking a bit more on how to attack the crankcase with a die grinder/burr and not mess it up.
Planning to remove the fuel tank and brake bail arm to enable better access.
I can make up a steel plate with 3 holes:
- Two small ones to bolt it to the crankcase flange
- One large 1 .875" diameter (47.62 mm) as a guide for the burr. This would give ~ 1.5 mm/side clearance between the bottom of the piston OD and the case ID
I can mount the plate and put a depth stop on the mill to prevent going below the desired depth. The plate will prevent the burr moving beyond the desired circumference.
Would 1.5 mm/side clearance be enough to prevent piston contact at high revs? Or should I go more? A 2" (50.8 mm) hole in the center of the plate would provide ~ 3 mm (0.125") clearance per side.
