Stihl West German O24 AVS / Upgrade to 44.7 Bore
9:29 PM
You have to go through your saw and figure out why it’s ruining top ends before you do anything else, or you’ll be in the same boat with the new top end.
That NWP looks like worn through plating. Seems to not be uncommon with AM top ends.
I’ll take a look at the PM now.
Paul Fithian
8:29 PM
Long Beach, IN
I trimmed the ragged melted front edge of the top cover and cleaned it up a bit.
024 AVS Top Cover Trimming.jpg 024 AVS Top Cover1.jpg 024 AVS Top Cover2.jpg
Instead of trimming the two rear top cylinder fins, anyone else try trimming the inside of the top cover like this guy did?
9:29 PM
View attachment 355635 View attachment 355636 View attachment 355637
Looks great.
Don’t ruin that cover. If you’re gonna go that way, I can swap you out a good set of oem 026 covers. The 024 covers look much better IMHO. 026 covers allow for the larger airfilter as well, but unless you’re porting the saw you won’t need it.
In the above video that guy wasted a lot of time on that jug. As they say, can’t make a silk purse out of a sow’s ear. Nothing beats an oem jug.
Paul Fithian
8:29 PM
Long Beach, IN
Brief update, Meteor kit has been returned. Following Doc’s prescription for this upgrade, more info in a week or so.
I greatly appreciate everyone’s help, adhering to one of my beliefs:
Understand what you don’t know, get assistance from those that do.
Paul Fithian
8:29 PM
Long Beach, IN
I had planned to share a compression test picture in this post, hoping for 200 PSI +. I was feeling pretty good about the assembly and how the Motoseal went on, thin coat painted with an acid brush.
Discovered a new problem after the cylinder was torqued down and I rotated the flywheel, could not get to BDC.
It appears the 44.7 mm piston OD interferes with the crankcase ID. This may be unique to my saw, however not sure if anyone else has tried to fit a 44.7 P/C on an 024 AVS.
There is some mismatch at the bore ID in my crankcase halves:
After some consultation with Doc, plan is to relieve case a bit with a die grinder and burr at the 11-1 and 5-7 o'clock positions to enable piston/crankcase clearance. Any other suggestions?
redline4
I'm huge in Japan
8:29 PM
Rosholt Wisconsin
I've seen that on a couple of my Stihls.
I'd take a burr to it too.
Paul Fithian
8:29 PM
Long Beach, IN
Thinking a bit more on how to attack the crankcase with a die grinder/burr and not mess it up.
Planning to remove the fuel tank and brake bail arm to enable better access.
I can make up a steel plate with 3 holes:
- Two small ones to bolt it to the crankcase flange
- One large 1 .875" diameter (47.62 mm) as a guide for the burr. This would give ~ 1.5 mm/side clearance between the bottom of the piston OD and the case ID
I can mount the plate and put a depth stop on the mill to prevent going below the desired depth. The plate will prevent the burr moving beyond the desired circumference.
Would 1.5 mm/side clearance be enough to prevent piston contact at high revs? Or should I go more? A 2" (50.8 mm) hole in the center of the plate would provide ~ 3 mm (0.125") clearance per side.
Shane¹
9:29 PM
Kentucky
What was the clearance with the other piston? Check that and make it similar it didn't hit anything with that one
Paul Fithian
8:29 PM
Long Beach, IN
Good point, Shane. We can do that without measuring, assuming the 44.7 mm piston just barely contacts the ID of the crankcase now:
44.7 - 42 = 2.7 mm/2 :: 1.35 mm per side clearance with the OEM 42 mm jug to the crankcase.​
So using a 1.875" metal plate template would be the right size, enabling 1.5 mm (0.060") clearance per side.
Common belief that at least 0.020" squish is needed to ensure the top of the piston does not contact the squish band, right?
So 0.060" clearance per side should be more than enough, right?
