Seachaser
- 2:00 AM
- Oct 26, 2022
- Georgia
I’ve done alot of muffler mods with additional deflectors up front, I much preferr getting the exhaust out and away from the cutting area/operator area.
Them front exits towards the wood tend to keep the exhaust in close proximity with the saw & operator. Just my observations from my own experiences with adding those deflectors in that/those areas
View attachment 354228 View attachment 354229
Took some time to switch from stainless welding (with purging) to machining cylinders. Started cutting on the 500i, looking for a reliable, yet torquey build for a daily use faller ............... lets see how @TINYHULK likes it after he gets it. More pictures coming this week as I progress to cutting the base and then porting it.
I boo-boobed my quoting …Nice lathe.![]()
You need a 500i ?I need one of these
You need a 500i ?
7x12 is the bare minimum. But not crazy accurate or solid. 9x19 is sort of the standard minimum. And they work fineFor the lathe illiterate. What type of lathe and minimum dimensions/features do you have to have to be able to machine cylinders?
Going to time it tomorrow morning and see if the cylinder is where I want it, or if she goes back on the lathe for a little touchup. Then I’ll think about where I want BD. I’m pretty much set on intake and exhaust, I’ll be pondering the uppers.how does this build compares to your personal 500? You mentioned you might copy it or try something different. Just curious
