WANTED Stihl MS 361 Shroud decompression plug
Trader history (4)
jmester
12:46 AM
VIRGINIA
I am looking for the rubber plug that goes into the cylinder shroud on a ms341 or 361 once the decompression valve is removed. Part number 1135 084 7100. The ipl says it comes in the grommet kit part number 1135 007 1003, but I am not sure that is correct. Local dealer says NLA. The plug is number 7 in the picture.
hacskaroly
2100 Fanclub Member
9:46 PM
Northern Idaho, Ehh
Fill the hole with JB Weld, it will be just the same, but better! :D
jmester
12:46 AM
VIRGINIA
Maybe that would work. But the install time is to long. Plug and play would be faster
jmester
12:46 AM
VIRGINIA
Would you have time to check on it and see if they actually have it? It appears that it has what I am looking for. It's the piece on the bottom of the picture on the left.
6:46 AM
That is in Bosnia, neighboring country.
They advertise sales of aftermarket products.
Is it OK if I check for OEM locally first?
jmester
12:46 AM
VIRGINIA
That is fine. Are you going to check both part numbers? I have a 1135 007 1003 kit here and it does not have the decompression valve plug in it.
Thank you
6:46 AM
Thank you
What is the part number You actually need?
If it is sold as a standalone part.
Maybe I missed it, too hot to think, just beginning to ease up a little.
