- 1:12 PM
- Jul 22, 2017
- San Antonio, TX
I'm try to figure out how to reproduce two unobtanium parts for the Stihl 1111 series saws. Specifically, there are two small parts that are only used on the full-wrap bars that are virtually impossible to find.
First is the actual mount, which is part 1111 791 1907 (looks like 1906 is an alternate number), or part 37 on the attached screenshot. It's metal, presumably magnesium alloy.
The other is the sealing ring, which is rubber with an embedded metal ring (I'm not going to worry about the metal ring at this point).
I have attached a few pictures of each. The mount is slightly chewed up because of where it's mounted - if the chain comes off, these catch hell.
I'm not worried about something being correct for a restoration. I just want something that will work.
So, how would you reproduce the metal piece? I know it can be CNC carved out of aluminum, but that might be cost prohibitive..
What about the rubber piece? Seems like this can be made using a mold or on a lathe.
Thanks in advance for any input!
Scott
Scott
