Stihl Br600 service question
Blackstone Brothers
New OPE Member
1:05 AM
michigan
I am a 15 year old boy, who just bought a used br600 back pack blower and am working on getting it back into running condition. For my lawn care business in the summer. When I bought it I realized that the fuel line was cut so, I replaced both lines and then realized that the primer bulb wasn’t getting fuel. I then replaced the carburetor and that fixed the no fuel to the primer bulb issue but it still won’t run. When I pull the string it is a little jerky and it kind of spiders. I was thinking about adjusting the valves, is that the right newer move? What could be the next step to try? What can I do to fix it?
Junk Meister
12:05 AM
Nebraska
Is that a4-mix Stihl. Valves need checked to ?.010 ? But there is a warm up procedure I Can't give you the details but do a search on valve adjustment 4 mix Stihl. Or wait for someone to CHIME IN.
and WELCOME to OPE
EFSM
12:05 AM
Extreme southern IL
You can buy a feeler gauge from Stihl or trim your own. Turn the engine over until the intake valve has shut and the piston is at the top of the cylinder. The valve clearance should be .004”
Junk Meister
12:05 AM
Nebraska
I read some where about the motor should be warm?? needs to get started then rechecked. Let ssomebody that does this often tell you how ..
EFSM
12:05 AM
Extreme southern IL
The whole point of having valve lash is that it allows the system to warm up without holding open the valves. I never adjust with them warm.
Junk Meister
12:05 AM
Nebraska
Listen to EFSM I don't do this for a living..
You might request a manual and IPL for your machine and someone might send you "STUFF" to your message box.
Junk Meister
12:05 AM
Nebraska
What is IPL?
Acronym for Illustrated Parts List The manual will be "Operators Manual And/or Service Manual. Service shoud be loaded with very helpful information Like setting the valves. or specs or trouble shooting.
