leadfarmer
Hot Rod !!!
- 10:52 AM
- Dec 28, 2015
- S Central PA
I think your right WillisAndy's 661 Betsy. That's what happened to the piston. Same spot
I'm sure. Got my 461 that way. Put together a good saw out of the better parts of two, used the rest and put a new tank/handle assy on the one I kept. A bargoon!Are you sure ?
It was the first of 8 or 10 that I ported for @leadfarmer's friend Andy. Supposedly the best running one, his favorite by far. Rodney sent the piston and ported cylinder back to me to get my opinion on it. The only thing we both could come up with was that the piston was dropped at some point in time and and weakened that lower left skirt corner. But now seeing that it has happened to someone else makes me wonder. The 661 has always shown intake skirt wear. Maybe that flange is cooling the skirt so much that it's not expanding and remaining loose in the bore, breaking the skirt. I have no ideaI started a thread on this but I’d love to hear a bit more about it. I’m baffled....
Looks to me like the skirt hit the internal intake flange and chunked it. This is the third time I’ve seen this. Twice on one saw, swapped top end and removed flange and been working it as a backup goof results (this saw had a year on it)
Second saw, first time it happened, about a month on it....
Both working flawlessly beforehand.
Not to hijack but any details on “Betsy” ??? Mod, timing, etc?
I'd think it would score before breaking the skirt, given all the scored cylinders we see without broken piston skirts. But I didn't expect to change your mindOr, not cooling it enough, and it expands and touches something. I still think that is what happened to the 461 I put a new piston in.
I agree. There's something in there without enough clearance, or too much.Well, what ever is causing it … I think it is more common on newer saws like the 461 and 661 than on older ones like the 660 and 460.
So that just makes me think it may be related to them trying to meet emissions, but I could be wrong.
Those two models are the only ones that I've heard of doing it. And those two are the only ones I know of in the Stihl lineup that are nearly identical regarding the piston, cylinder, and crankcaseWell, what ever is causing it … I think it is more common on newer saws like the 461 and 661 than on older ones like the 660 and 460.
One set of magnets provides spark while the other runs the mtronicParts are just plain expensive for any 661C. For example: $110 for a pull cord housing that does not even include the pull cord, spring, pawls, label, etc. Over $210 for a tank housing, $100 for an outside handle bar, over $110 for the carb, etc. The list goes on and on.
A few early 661C saws sold around here had defective ignition modules that the dealer replaced while under warranty. I also find that repairing a 660 is much easier and far less time consuming.
Quick question: why does the 661C flywheel have two sets of magnets, each at 180 degrees from each other? That caught me by surprise. I'm sure the second one is there for a purpose. Do you suppose Stihl is masterminding a 2-cylinder engine for the future?
Friend says he’s seen this in several 461’s! I’m removing the “stuffer” from now on. Testing one now but feels like more torque without it.
Interesting. So that is perhaps why the IM (or the flywheel) on the 661C might be overworked and why it often failed during early production? Two possibilities for failure rather than just one.One set of magnets provides spark while the other runs the mtronic.
