Orangeinthebarn
- 11:24 PM
- Sep 1, 2017
- Tennessee
I’ve looked online and can’t find this new chain anywhere
You need about 6 drive links minimum to even get the chain on the bar and sprocket at the same time, unless you pop the sprocket off and assemble it as one unit. I have alot of McCulloch saws and their 20 " bar takes 70dl , it would be physically impossible to mount a 70dl chain on a 72dl D009 bar and then mount it without disassembling the sprocket, something is off ?the bars are d009 mounts, this was brand new chain i just made up off a full roll. i have never run into this before. at full count the tension adjustment is just about maxed out with out running the saw.
I’ve run both on a stock and ported 261 with a 20” cannon super mini bar mostly as a climbing saw. Years ago had the kit from stihl which came with the bar, chain and sprocket. I prefer the 23rs pro never did any timed cuts though. ps or ps3 can be hard to find up here most dealers I’ve dealt with only carry the pm which doesn’t make sense when climbing or working out of a bucket.has anyone tested this new chain vs 63ps on a 261? I have a 16 inch 3/8p .050 60 dl stihl bar for 261 and its pretty fast. I prefer the 346xp variants over any 50cc saw though
I purchased 2 loops of this chain from eBay last year.I’ve looked online and can’t find this new chain anywhere
Not really sure what its called exactly. But it is. 325 RS Pro. Comes in full chisel.Readily available in round ground, not sure if NK is square? I use a 2 in 1 and it is very quick and efficient while retaining very good cutter geometry in my opinion. Every other time or so I hit the gullet with a normal round file.
It,s the standard here in Canada, 058&063 is notBought these loops at my Stihl dealer here. If you can't find any I can look into it.
Though the dealer did not have the exact size I needed. They took an "in stock" size
and cut it down to match my bar. I wish you well in your search. As always its much better
to find stuff local if you can. It invests in your local economy and helps local business.
How much can you drop the rakers before it gets too grabby? Haven’t tried yet. ThanksHere is 325rsp in anger at races lately. Me in green shirt.
Standard is 17thou. 25thou is good. 30thou is gabby.How much can you drop the rakers before it gets too grabby? Haven’t tried yet. Thanks
Got mine out and tried it today. Didn’t check to see how low the rakers were. Hadn’t run it much or in a while. Hums pretty good!Standard is 17thou. 25thou is good. 30thou is gabby.
