Stihl 090 rebuild
Iron.and.bark
3:25 AM
That's the thing mate, an 090 will take money out of the bank to do properly, unless you get parts at a good deal..
I have 3 husky 394/395's on the go. Will have spent north of $1k in parts to get them running (which will yield a nice profit), but still have to carry the cost till sold.. Big saws = big outlay for potential profit..
Fix and flip other saws and do this one properly for yourself :)
Oh and you know I'll buy any big dolmars you find.:borra2:
Brewz
6:25 AM
Hunter Valley - Australia
whats a Dolmar?
Your a sick man!
Yeah I know what your talking about.
The saw haul I got was all big muscle saws.
The smaller ones are gone for a bit of profit but I am finding if you tap the correct market for old saws, the big ones can reap the best rewards.
I will probably keep the 090. Its just something that every enthusiast should have and I have always wanted one.
I guess that's another reason I want to do it properly.
I have a couple others that I have decided to keep that are being sold after receiving good offers.
My efforts to built to a high quality are paying off as people are impressed, tell their friends, then their friends contact me asking if I have saws for sale.
People will pay good money if they know they are getting something good.
Its the unknown that kills a saws value
merlin7734
Active OPE Member
2:25 PM
North Florida
Might I suggest... To avoid going Chinese, because a build like this deserves more... Doing something like a fabricated top cover?
Something like this small block Chevy valve cover and keep looking for OEM?
Sent from my MX2020 Secure Satellite Uplink.
Brewz
6:25 AM
Got some time to work on the big girl today.
Pulled the flywheel to get at the ignition so I could fit up a new spark plug wire.
Found this interesting repair.
Looked in the box of spare bits that came with the saw and there was another flywheel, but it is busted.
I also found that the key was worn down and sitting flush with the shaft.
I cut a couple strips of coke can to hold the key up a bit and it worked perfect.
Now have new spark plug wire fitted, ignition module checked and flywheel fitted back up with the key actually holding it in place.
Brewz
6:25 AM
Then I found the locking pin that holds the pull start coupling to the flywheel has been sheared off.
There is not 1 part of this saw that does not need something fixed.
I drilled out another hole, tapped it to 4mm and wound in a bit of 4mm high tensile screw with the head cut off. Added some thread locker for good measure.
Touched the sides down to size and it works great!
Brewz
6:25 AM
Next was the choke flap thingy
The shaft was badly worn and the spring was cactus, so it was flopping around like a rag doll.
I ordered a rebuild kit and fixed it up.
Its as good as new now!
Bent spring and shaft sitting at an angle:
All fixed:
Brewz
6:25 AM
The base plate had a nasty dint in it that was leaking fuel when i got it. You can see where it has cracked through in the bottom of the first photo below.
I ordered a Chinese base and it is fantastic.
Fit and finish are great. Very happy with it.
Replaced the fuel filter while I was in there.
Brewz
6:25 AM
Dug the bar oil tank cover out.
First issue is the aux oiler button has a stuffed o-ring, but I have ordered spares in all the sizes I need for the 076 I am building as well, and a 5 x 1.5mm will seal it.
The saw case flange for the cover had some high points due to dints from its trip off the back of a truck at speed, so I filed it flat to make sure it will seal.
I found that the bottom corner where the wood chips hit was almost worn through, so I used some duct tape to make a dam wall and filled it with JB Weld.
Will remove the tape and file it flat tomorrow once set to make sure there is a good surface area there for the gasket to seal on.
Brewz
6:25 AM
With metal putty setting on the saw, I turned my attention to the poor old handle bar.
It is properly bent, mangled, hacked, welded up crooked and just plain depressing to look at.
Now I know these AV bars are available by the dozen on every corner you turn, but I am up for a challenge and plan to make it good again.
First up I cut off the top bar with an angle grinder and will make a new one from pipe...... it is un-recoverable.
With a trusty propane torch, hammer and vice, I heated, and bashed it back into shape and am very happy with how it ended up.
Will make a new top section and weld it on and when covered in new handle bar rubber, should come up nice.
Before:
This shot really shows just how messed up it is/was/kinds still is
After:
Brewz
6:25 AM
Doing some reading, the little choke flapper thing is actually a governor.
As speed increases, it uses the increased air flow to close off the choke and richen the mix up, stopping over reeving.
The way it was before I fixed it up, it would have been shutting off the choke very easily with the bent stretched spring.
Its much stiffer now.
I have a little tingle of excitement as its looking less nasty after every little repair.
A wise man once told me....... A big job is just lots of little jobs, and this saw sums that up well!
Brewz
6:25 AM
Next major task is to try and repair the top of the cylinder where the spark plug screws in.
I know people suggested milling the top down but I really think all it needs is a touch of devcon in the recess to give a full seal.
Speaking of spark plugs..... does anyone know if the 090 runs on the same spark plug as most other saws of does it need something different?
Brewz
6:25 AM
Its had a helicoil put in but the chunk missing kills the seal.
I plan the fill the gap
merlin7734
Active OPE Member
2:25 PM
North Florida
My WECSOG mindset says use foam and wrap it in golf club wrap? Not sure that is even something a person can buy?
Nice progress! This is my favorite current build on the site!
Brewz
6:25 AM
The repair to the worn case part on the oil tank worked out great!
I dropped by the local steel merchant and found an off-cut bent length of black steel tube exactly the same OD as the OEM handle, just a little thicker.
Got it for next to nothing due to the slight bend in it which didn't worry me as I was planning on bending it anyway.
Bent a section of it over a log round and cut it off a bit long so I can trim it back to the perfect size for welding once I have the front AV mounts fixed up.
Got the motor back on, replaced the fuel lines, and fitted up the new rear handle parts
hseII
Heef
2:25 PM
West Georgia
You & I share 2 hobbies, I see.
Lapua is some fine Brass.
