Bob95065
- 11:54 AM
- Nov 7, 2016
- Felton, CA
I have a worn out 066 that was given to me by a friend that had a saw shop near me. The saw was just plain worn out. The cylinder walls looked like mirrors from use. Air filter was clean when I got it.
My plan with the saw is to build it into a dedicated milling saw. I got a replacement cylinder for it. I plan on replacing the bearings, piston & rings along with anything rubber on it (seals, impulse line, intake boot, carb kit, A/V buffers).
The questions are should I go with a pop up piston? Base gasket delete? Mild porting? What are the get mods for a milling saw?
TIA,
Bob
TIA,
Bob
