Stihl 032 AV Electronic Trigger Unit
Djj450
Active OPE Member
7:38 PM
Are there any solutions out there for replacing this faulty trigger unit
SE#1
3:38 AM
Pa
There is another thread in this site that explains how to test and replace if necessary. I'll see if I can find it and attach. I remember reading it.
legdelimber
3:38 AM
N.C.
Wasn't there someone doing repairs on some ignition units? I believe it it was bad capacitors needing replacement. Not sure what web site I saw it on.
Seems like the guy posted as "Foggy Sails" or something similar.
SE#1
3:38 AM
Pa
Yes sir, not every time is it the capacitor, but a majority has been my experience. Definitely worth investigating. I have never personally worked on this specific module, but have tested many others and the capacitor has been faulty on several occasions.
Djj450
Active OPE Member
7:38 PM
There suggesting using the 031av module in that post but I'm hesitant in buying one just in case it doesn't work with my setup. The 032 IPL only shows 2 setups but the post mentions 4 different versions on the 032. One being points, the donut under flywheel, trigger unit and then the later electronic coil. Without seeing bulletins for the 032 changes
I was thinking of pulling the guts out of mine and having a go at repairing it. My coil tests good with resistances in spec and tested on a coil tester but get no spark when in the saw. What's the best way to remove the epoxy from the chip without mangling the casing?
SE#1
3:38 AM
Pa
The epoxy is a real headache. I use tiny screw drivers and pics. Time consuming, much easier and faster to replace. That is a side project just for enjoyment, not if ya want to get her repaired.
SE#1
3:38 AM
Pa
Are either of these a possibility?
Djj450
Active OPE Member
7:38 PM
Bit of an update after some more troubleshooting with another working saw I figured out my trigger unit and coil is fine. The issue was grounding related, my saw has helicoils installed that secure the coil to the chassis so it wasn't grounding. I installed a ground pigtail from the coil to the trigger unit and now I have strong spark.
