MS661 AV help
Jimmy in NC
7:58 AM
North Carolina
Have a customer that is looking to firm up their 661's A/V. I know that has been an issue before but I have not kept up with the forum or these saws very closely. Are there firm springs or options to add some rigidity to this AV system?
singinwoodwackr
5:58 AM
moon
sawmikaze
7:58 AM
steeltown
So I am the guinea pig on this one? Nobody has run them?
I have them in a lot of saws, there's not a lot to say about them. If you want a stiffer/firmer feeling saw - that's what these kits do.
IMO this 661 kit from WCS is incomplete. They need to throw in the buffer that sits behind the coil. That piece is in the 462 kit.
So, last time I did 2 661s at the same time I ordered the 2 kits and also a kit for a 462 since it has the 2 buffers in it that fit behind the coil.
Jimmy in NC
7:58 AM
North Carolina
Thank you so much! Am doing 2 saws so I will order the 462 kit as well. Exactly the type of info I needed.
Thanks to all that have helped.
sawmikaze
7:58 AM
steeltown
It'll be self explanatory when you get the kits. Idk why they don't add that other piece in the 661 kit.
jmester
7:58 AM
VIRGINIA
I have the fallers suspension in 2 500i they firm the saw up nice. Seem to last a long time.
