Need help adjusting high low adjustments on carb of Fs74. Where would be a good startin settings for idle/air, H, L? Will not currently start at all. Thanks in Advance.
There are no turns on the LA screw specified. Adjust it that the cutting attachment doesn`t spin at idle and give it around a half turn counterclockwise more when the attachment doesn`t spin as safety buffer.
