Sthil Fs74
Dan1129
New OPE Member
10:36 AM
Iowa
Need help adjusting high low adjustments on carb of Fs74. Where would be a good startin settings for idle/air, H, L? Will not currently start at all. Thanks in Advance.
DND 9000
5:36 PM
Germany
Basic setting for the Walbro WT-227F carb is H=1 and L=1
Idle speed is 2800 and full throttle 10500
Dan1129
New OPE Member
10:36 AM
Iowa
How many turns from seated on idle/air screw ?
DND 9000
5:36 PM
Germany
There are no turns on the LA screw specified. Adjust it that the cutting attachment doesn`t spin at idle and give it around a half turn counterclockwise more when the attachment doesn`t spin as safety buffer.
Dan1129
New OPE Member
10:36 AM
Iowa
Ok I'll give those settings a try. Thanks DND 9000, Appeciate it.
