SOLO Solo thread
Brian Webster
10:43 AM
Central VA
Had my 643ip on downed tree duty today while working on treestands.
Jimsz
10:43 AM
Walterboro sc
That is fantastic! Keep that contact/friendship. Without it or the ability to read and speak German I have little hope of getting parts. Either I make the part or find a "parts" saw.
Marshy
WFO Cutting
10:43 AM
Mexico NY
Hello gents, I could use some help with a Solo 667. Not familiar with them but figured I'd give one a try. The saw will start run some and die. The guy I got it from supposedly went through the fuel system. New lines, filters (has a single line that goes into tank then splits with a T into two filters), new carb kit...
Can someone tell me, is the dual filter homemade or stock? Also, what's the impulse on these through a carb manifold block or do they have an impulse line? Lastly, there appears to be a fuel tank vent line but it comes up into the carb housing area and has nothing on the end of it. If you turn the saw upside down fuel will come out the line...
The plug seems wet after it dies and I take it out but I checked spark and it has a good strong spark. Possibly the impulse, diaphragm or metering arm isnt set right..? I need some ideas. Thanks.
20190909_190231.jpg 20190909_190250.jpg 20190909_190308.jpg 20190909_190313.jpg
Homemade
10:43 AM
Wisconsin
I have one. The fuel line that is capped off is the tank vent. Should have a grub screw shoved in the end. Mine runs like crap and i need to put a new carb on it. I’ve cleaned it several times and put new kits in it, still can not get it to idle good. I’ve checked for air leaks and it holds. That project got shelved till I have more time. Guy I know in Illinois has parts.
brandonstclair20
10:43 AM
Starkville
I have a solo 651sp and I need gas and oil caps. It appears that 643 caps will fit but they have a different part number. So which caps do I need? Solo 651 caps show up as NLA.
Lee H
7:43 AM
cape cod ma.
Saweet little Solo. Sorry it got messed up in shipping. Looks great now.
Sawrain
12:43 AM
South.
Is the 643ip everything the specs suggest it is?
I’ve been thinking of a new chainsaw for my Honda quad.
Brian Webster
10:43 AM
Central VA
I think it is. It's very light, easy to start, cuts great and it's reliable. It's my go to saw for light clearing, cutting paths and treestand work. Finding one might be the only issue.
Sent from my SM-N975U using Tapatalk
Sawrain
12:43 AM
South.
Indeed, I have never seen one, or know of anyone who has one.
As cheap & obviously cheaply built as the MS170/18o is I'm finding it hard to upgrade from for this purpose, as any seriously better saw very quickly jumps in weight to the likes of a 346xp, 2153, 026, Solo 650, still lite, but not quite what my ocd wants.
