Solo 665 thread
Deets066
AKA Deetsey
4:28 AM
How's the bigger carb install coming?
Backwards
You can stretch the impulse and slip it over the fitting on the carb.
But it will tear a hole right through it after a few seconds. :(
Intake ring needs to be changed or throttle cable modified.
Also plan to try am make a 90 * v-stack so I can get an air filter to work
4:28 AM
Husky parts are slow sometimes.
3:28 AM
Put the carb on and just couldn't get it to fire, pop, nothing.
Turns out carb won't push fuel when you get the fuel and impulse hoses mixed up :confused:
I blame everyone else when I do something like this
Deets066
AKA Deetsey
4:28 AM
Ok, so I thought the timing was a little far before, but didn't sound too bad. I can hear it more with the new carb on
