So what did you buy today
SimonHS
6:32 AM
Yorkshire, England
And that's in the box above the pressure gauge? And the black drill chuck next to it is for threading?
The pressure gauges are Dial Test Indicators for checking small measurements or run-out of shafts, or things being turned on a lathe.
In the box above is a morse taper lathe reference bar, for checking, adjusting and setting up lathes.
The black chuck is a slitting saw arbor.
Similar to this when a saw blade is added:
Sloughfoot
10:32 PM
Norcal
Nice! Baja Designs makes good stuff. New winch bumper I put on our old Toyota awhile back had holes for fog lights I didn't want. Just to fill the holes on the cheap I put in lights from a company called Nilight. Stlll work 8 years later but I hardly use them because they're not on a keyed circuit. Forget to turn them off.
Partner
7:32 AM
Poland
They have a low power consumption and you can connect them to anything in the engine
Squareground3691
1:32 AM
New England
I have a switch panel I put in to accommodate the different lights,
Partner
7:32 AM
Poland
Wired speaker for phone, I cleaned it / $1 🤠👍
Sloughfoot
10:32 PM
Norcal
Our 07 has a factory switch panel below the radio. Has a couple of factory switches in it and about 8 knockouts for typical rocker switches. My fog light switch is there with the miscellaneous 4wd stuff.
furb
1:32 AM
PA
Wednesday a guy pulled in to where I’m with a truck full of saws and other two cycle junk with this buried in the load. I told him I’d buy it if he brings it back today. $5
Partner
7:32 AM
Poland
It's bad 😉 it can't be disassembled, maybe the transmission and electrics behind the engine will remain along with the speed controller / $5
Partner
7:32 AM
Poland
I drilled a hole in the bearing housing near the commutator, added grease and sealed the hole with hot glue 🤠👍 I didn't know it was possible 🤨😉 now it works well
Woodtroll
1:32 AM
Mtns of SW VA
I like it when somebody’s not afraid to try to fix something. It’s already broken, what does it hurt to try (unless it’s a life safety threat or high risk of expensive failure, obviously)? Sometimes a band-aid repair will keep an object going for an unexpectedly long time.
Good job!
Powerstroke Cowboy
11:32 PM
Montana
I'm famous for greasing non greasable/sealed bearings. Generally a bearing only goes bad when it runs out of lube.
Good job!
