Simplified---Adding A High Speed Circuit To A WG Carb
11:06 AM
This pilot hole is the right size to run a 4mm bottom tap in to create the threads...
....but first you need to drill into the main well to feed the main nozzle.
In order to keep the drill centered, you need a steel bushing that just barely slides into the hole.
I make the hole into the well .050", so my bushing has a hole that my .050" drill bit just fits thru.
Simple huh?
11:06 AM
To feed the new high speed circuit, I drill a .080" hole here.
Notice that I cut a channel over to it. This might not be 100% necessary. I had a saw that was leaning out in long cuts once, and adding this channel helped. I'm not interested in debating any aspects of this mod. Use it or not....your call.
I counter drill a place here for the oring.
Pintail120
5:06 PM
United Kingdom
thank you kindly for writing this up, very grateful !
I have only one question:
I assume the 4mm hole is the existing hole, I dont need to clean this up ? all I do is tap the M4 thread to the bottom of the hole ?
Would you consider doing this mod for me if I posted my carb to you and I paid for your services ?
I dont have the tube spacer and you have done this job so many times that I know you would get it done properly.
thanks & regards
Gav
12:06 PM
I have a question. Does the original nozzle have a hole in the bottom of it to feed it? The new nozzle is devoid of one I see.
So a new nozzle is necessary? This seems akin to the echo 620P carb nozzle if what I am seeing is correct.
Nice thread Randy. Thanks for taking the time.
11:06 AM
thanks & regards
Gav
The pilot hole is a bit odd shaped near the bottom. So yes, in order to get the pilot all the way to the bottom, it does need cleaned up. I was just trying to keep the instructions very simple and basic.
Yes....I would do your carb. Send me a message.
There is no feeder hole in the base of the nozzle. It has two holes in the groove to feed it. If you can remove the original nozzle without damaging, you can reuse it.
Racer
5:06 PM
Earth
Hello all. I have questions. I have old husqy 3120 and old carb without H hole like in 1st post this thread. I can modified this carb and added H jet or need like 1st post?
