TravisJellison
- 8:19 AM
- Nov 15, 2016
- Byron.IL
Hey everybody, I recently got a "basket case" Silvey RSII. I ordered a SCARR upgrade slide kit, and multipoint dressers.
I finally got it all set up. I have never had a square grinder before, but I can file square by hand pretty good, so I know how the cutter should look. Not getting the cutter to look how I want on the grinder though.
I feel like I am getting into the tie strap too much, I know I can expect to hit some, but I'm hitting into the rivet.
Can some of you so pictures of your set ups?
For example, where on the wheel do you bring the tooth in? The middle or more to the front?
How high or low is the slide/carriage?
I feel like maybe the wheel is too low, if that makes sense.
Thanks!
Thanks!
