- 4:08 AM
- Sep 4, 2016
- Wisconsin
Well John Deere sells a set that are 5” each side so I figured if they will warranty the tractor with them on it if I buy 3-4” ones is should be fine. The jd ones are 600$ a set
I think you'll greatly appreciate having them on there.
Also, I assume you can buy the same tractor with ag wheels which could be moved out to a fairly wide stance. I wouldn't worry about breaking stuff if your r4s with spacers are within the same width range as you can achieve with ag tires
