- 3:44 AM
- Dec 31, 2015
- East Jordan, MI
On youtubeWhere's da vids???
Where's da vids???
I got one too. On a bastard saw.On youtube
Corn and mushroom cans are for saw muffs. Duhsoup cans ain't for chainsaw mufflers
Where can i get theses muffs? Asking for a friendCorn and mushroom cans are for saw muffs. Duh
@Armbru84 might still have the picWhere can i get theses muffs? Asking for a friend
Gas welding with old coat hanger ain't bad if your good at it. Oxygen added torch is best for that. Snapon 120v mig is quick and efficient for myself most times. Might look for thinner wire under 0.028I have a tig rig in the garage, it is also my stick machine which is the way it generally stays set up.
I braze mufflers because I can be done in the time it takes to swap processes, which is less than 5 minutes.
Still solid at 1200 degrees Fahrenheit, silver solder or brazing alloy has more than enough strength for a muffler mod, unless your muffler is beginning to glow red, you’re still at full strength.
45% silver with white brazing flux for the initial tinning and brazing (most of the time all you need), 15% silver once you have already made a bond to the base metal. 15% has a much wider liquidous range and allows you to build and fill large gaps by controlling your heat.
I have yet to try tig brazing which Al swears by, mostly because I’m a stubborn butthead that doesn’t like to try new things.
That’s where all the coat hangers went.Gas welding with old coat hanger ain't bad if your good at it. Oxygen added torch is best for that. Snapon 120v mig is quick and efficient for myself most times. Might look for thinner wire under 0.028
0.020 would be nice.
My buddy tried using a coat hanger but the plastic kept running off when it melted!Gas welding with old coat hanger ain't bad if your good at it. Oxygen added torch is best for that. Snapon 120v mig is quick and efficient for myself most times. Might look for thinner wire under 0.028
