- 12:20 PM
- Jan 8, 2016
- Farmington, CT
In this case....the crank had been pulled through the bearing as far as it will go....so the spacer rides on the bearing....not the crank. The clutch and washer sandwich it. If I do up the clutch/washer and spacer on the crank that has no bearing, the spacer is STILL sandwiched TIGHT. ...and I can get the e clip on.
It seems like the spacer is too long, but the tolerance of what fits and what doesn't is super tight.
I ordered some more spacers, so I'm going to mod this one and see if the whole shoot fits.
