Saw video thread
WillG
3:08 AM
Norwich CT
I predict the 346 XP will steal the Stihl's lunch money...
Once it's broken in I'm putting a dual port muffler on it as well. Considering the 346 pulls more rpm, is running a narrow gauge chain (.050 vs .063) I'd definitely put a dollar on the Hooskie
Duane(Pa)
It's the chain...
3:08 AM
Centre County
Have fun, just don't ruffle dad's feathers too much lol!
chipper1
3:08 AM
Grand Rapids Mi
Dangerous rotten big pine. If you look closely you can see the dirt kick out of the stump when it hits ground.
Sweet.
Cactus pine?
I have one that's about half that size do take down. It has the same "cactus" leader of to the side like that one, I need to remove one branch that will hit the pool that's at about 20ft, gas polesaw from the bucket of the Kubota. Maybe I'll do a video of that part, the safety guys like that sort of thing :cursing::cursing2::taptap:.
This one was hard leaning into the tree line and was rotten, cut it at about 10' and left the notch open so the hinge would hold(also had side lean", it worked as planned, but caused the top to hit first and broke part of it out.
Lay of the day lol. It chucked a good bit of dirt up.
This was the other lead off the same tree.
Not as dramatic, but fun.
malk315
Running Saws for Therapy
3:08 AM
Lancaster, MA
The new bull horn muffler and bar/chain for the 365. Hopefully good weather this weekend so I can make some test cuts.
Sent from my Pixel 3 using Tapatalk
malk315
3:08 AM
Lancaster, MA
Any of you guys recommend a replacement dog that with a little bigger teeth to help protect the exhaust on this mfer? Hoping to avoid crazy big west coast dogs... Something between stock and obnoxious.
3:08 AM
The inner 562 west coast spike and slot the bolt holes to fit.
malk315
3:08 AM
Lancaster, MA
Thanks Mason I'll check that out. Did a piss rev tonight and man does it have pressure coming out when at idle ... Nice "Pop Pop Pop" sound at idle like most 372s sound. Can't wait to see what she does in wood.
ferris
9:08 AM
Germany
Maybe u should cut the pipes in the middle, then you don’t have this problem
3:08 AM
Buy the whole full wrap kit and get the spikes with them. They’re the size they should put on them to begin with. The 5 point pro safety are too big for a 372. Ive tried them and you have to have a real light hand to use the bottom point.
