Saw video thread
11:47 PM
I find some saws it doesn’t really matter if there just a little fatter than optimal and others it kills the power.
The issue is, no 2 opinions of optimal are the same. Without tuning in the cut or accurate unbiased timed cuts, we'll never know. But like you say, on some saws, the tune is worth quite a bit. I've seen 50% difference in cut times on the same stock saw and neither were 4 stroking in the wood.
11:47 PM
A 2166 was actually the saw that I checked with in the above post
Wow, maybe I need to revisit testing lol. I tried with 372xt at 13,800 with unlimited coil and tuned at limiter with blue coil. Maybe it was because the saw made more power with the blue coil vs black?
11:47 PM
That's very possible. I've noticed differences with unlimited coils vs not.
Also, the rwj is one of those carbs that require a 1/4 turn to be able to tell a difference, whereas on others a 1/4 turn will go from lean to a solid 4 stroke in wood. So even though someone thought they leaned it way out, they didn't change the tune much at all
srcarr52
11:47 PM
Iowa City
Blue and black coils fire at different times, if I remember correctly the blue coils fire about 5deg ahead of the black coils.
11:47 PM
I noticed the blue coil don’t like to be advanced as much as the unlimited coil, which supports what Shaun said. I also used a unlimited coil from a 350 husky. It’s different than the 372 black unlimited and blue limited even though they will both bolt up. Don’t like the way the 350 coil idles at all on the 372XT. Works ok in the cut though.
beaglebriar
The Peanut Gallery
11:47 PM
Warren Center, PA
Blue 346 coil works great on them.
11:47 PM
I'm running a black coil from a 2149, and it seems to do pretty good.
On a 372XT? Mine was very erratic and hard to get the idle to be consistent on 372xt. Swapped back to stock coil and problem gone. I’m also running a early lighter 371/372 oe flywheel which might make a difference. Coil could have been bad too... but who knows. I’m leaving it alone since it works good now. Lol
p61 western
Ol Mudflap
8:47 PM
GFY
If you're running that on your 346 give it a little timing advance, 1/3 of the key or so.
Running it on a 372 oe.
