Saw video thread
12:43 AM
Yes sir. There is an adjustment over the left carb bolt on the rear of the carb under a brass welch plug. Drill and pull that plug . It affects topend adjustment and mine ran better on top at 1/2 counterclockwise which richened it from what I saw
Thanks. I have a rich off idle bog. Do you think it would affect that?
12:43 AM
I could use some help figuring out the rich bog after a long cut
My 2253 got that rich bog recently and had to be reset with latest firmware. Problem gone. Thankfully bob isn’t too far from me. I hear the 46 is problematic, my 562 with the el48 has been pretty good to me. If it was ran stock for a long time then modded it might throw off the computer?
12:43 AM
I messed with the “L” screw on my 2253 and it fixed bog for a little while. Then it came back. Resetting is the best option when these things are modded IMHO.
12:43 AM
My 2253 got that rich bog recently and had to be reset with latest firmware. Problem gone. Thankfully bob isn’t too far from me. I hear the 46 is problematic. My 562 with the el48 has been pretty good to me. If it was ran stock for a long time then modded it might throw off the computer?
Is there a way to reset the autotune? This is the first 562 I've worked on. Not familiar with them
12:43 AM
One way I heard without hooking up to computer is to get a 10 foot log and do rip cutting keep the motor loaded for like 5-10 min.
Hedgerow
11:43 PM
Lol. Could ziptie it wfo with the chain brake on :D
my 562 has the old el46 carb too..
Same rich hesitation after it's good and warm and has been running for a while.
It started about 200 tanks ago and is still doing it LOL
*f-word it...
Run the dog *s-word out of it LOL
12:43 AM
*f-word it...
Welp, I might. But it ain't mine. It belongs to our brother @mdavlee
12:43 AM
If it doesn't die idling it will be fine.
It idles fine. Starts fine. You can hear it in the 2nd video in between cuts when I'm not in the camera. I'm gonna play a little more with the transfers tonight and see if I can get a little more
Hedgerow
11:43 PM
Man, I don't know now..
I hear he's a picky sumbich...
You better stick them sausage fingers down in the carb and tickle the low side jet..
If it throws up, you went too far....
Good luck man.
