Saw video thread
awol
1:31 AM
Cabool, MO.
Have you ever heard of "blueprinting" or "balancing" a four-stroke racing engine? I have done it, and it involves weighing the pistons and making the counterweights on the crank match the weight of the pistons, as measured by the balancing machine.
The amount by which we change a saw piston is almost inconsequential at the speed which it runs; try it on saw with no anti-vibe though, and you will have a different view.
CR500
2:31 AM
Western NY
You have heat in your shop J?
Sent from my non internal combustion device.
jmssaws
Banneded
1:31 AM
Yes I've built many race motors and have had lots of them balanced,there multiple cylinder motors with multiple pistons.
A single cylinder engine is balanced by the flywheel. It is externally balanced
Piston weight has absolutely nothing to do with it.
awol
1:31 AM
Cabool, MO.
There may be exceptions, but every saw flywheel I have had on the balancer is statically balanced; it spins smoothly on its own, is not in any way responsible for balancing the rest of the assembly.
Unlike a Chevy sb400!
jmssaws
Banneded
1:31 AM
OR a 454.
2:31 AM
289, 302, Boss 302, 428 CJ all had some external balancing on the flywheel. 390 & 427 did not, which is why they held together better! The balancing on the external was a combination of the crank counter weight & the flywheel imbalance.
Deets066
AKA Deetsey
2:31 AM
It was 76 here today. Crazy
Not so nice here today
