Saw video thread
Chainsaw Jim
Con Artist LLC
2:47 AM
Springfield Oregon
Not sure I follow. I was like drf256 and was comparing to a car or bike engine.
I was referring to the balance of a chainsaw crank and comparing it to the balance of a car tire. Then thinking of different piston sizes relating them to different gears. A simple analogy that isn't common slang or easily understood by normal people because that's the way my stupid mind tries to work most of the time.
X 66 stang347 X
5:47 AM
Georgia
I have a 2mm stroker crank in my redline boat motor but there's kits for that. I mostly noticed out of the hole torque with it.
awol
4:47 AM
Cabool, MO.
Put up some nice videos please. Lol
Well I really don't have any "nice" videos of it, that's why I haven't posted any! It's kinda been a disappointment, I just have to get back in it and figure out what to do with the ports.
Here it is with .015 out of chamber and a base gasket, squish is .015, and ports are untouched. The muffler has an enlarged outlet, and the ignition timing is advanced 12 degrees.
jmssaws
Banneded
4:47 AM
A saw is balanced at a certain rpm.
Cut the counter weight off the flywheel and see if it makes a difference.
The piston has no affect on the balance of the rotating Assembly.
It's balanced with no piston or a 10lb one.
The piston goes back and forth not around.
