- 5:58 AM
- Dec 29, 2015
- Ontario, Canada
The porting added about 1500-1800 rpms to wot and about 1000 rpms in the cut and made the throttle response quite snappy. The lean on power also improved. Before porting I could only load the saw down to around 10k before the chain would want to stop. After porting I can load the saw down to around 8500k before it wants to stop.CFB, your saw even looked strong before it was ported, how much more do you think the porting added?
Also, what filter is under the cover (I would say the Black saw, but they are all Black!)
Now that right there is a beast of a saw! Looks great Tony. Nice workGot my 084 in some 3 foot wide, long dead, rock hard, gnarly red stringy bark today.
Chain was off the roll Oregon 404 full comp full chisel and had done several runs already.
Saw ran great and is really strong.
Pulled the 36" with a 404 8 pin no worries
Good filters.The porting added about 1500-1800 rpms to wot and about 1000 rpms in the cut and made the throttle response quite snappy. The lean on power also improved. Before porting I could only load the saw down to around 10k before the chain would want to stop. After porting I can load the saw down to around 8500k before it wants to stop.
The saw with the air filter cover is Dalls saw. It has an AM white pleated air filter on it. (The same filter that Jason likes)
I don't know.What piston you gunna run?
Planning on trying J. The 54mm BB I have here has some tiny tunnels though. I'm wondering if that would add a ton of velocity because of the smaller volume, or whether it will just be a dud. I could always weld up the tunnels and make them bigger.Anybody built a 044bb that ran good?
Video?
Don't work that way on saws. I used to think the same.I've wondered about the bb kits and a bb460 kit on a 440. Would the added weight of going 2mm or 4mm oversized add any vibration. I would think the counter weight on the crank would be balanced for oem size/weight piston?
We need someone to come out with a stroker kit fir 440's, 660's and 880's. Lol
That would be like needing to change the balance on your tires for each gear you use.Would the added weight of going 2mm or 4mm oversized add any vibration. I would think the counter weight on the crank would be balanced for oem size/weight piston?
