Saw video thread
Deets066
AKA Deetsey
6:47 PM
I bought the saw like this. It was straight gassed I think and stuck the ring in the groove letting the piston rock just enough to catch. There is a small hunk this size that came off the piston crown too. There is a really nasty lip around the ports. I can see why it hung. But will be an easy fix
6:47 PM
Well...
Metal air filters rule. I've never had a metal filter lose rpm.
Fwiw, to change from an early metal filter to a late 026/MS260 filter requires a different tank vent, a different carburetor, and a different rear cover.
This is @zeebee413 026. It lost 1000 rpm with the modified nylon airfilter. I repeated the test and it's true. But does it cut quicker?
This was the jug you saw in the NWP thread. It's 4 stroking at 16200. 220 psi compression.
