WillG
- 9:10 PM
- Oct 10, 2019
- Norwich CT
Solo 654
Yup FIXED!Seems to be an Echo in here.
An Echo 590 with an aftermarket Ms460 cylinder and a 372 carb, it runs good and was holding 12,700 RPM in the cut but I can't seem to get this crap AM carb to tune so I'm looking for a good OEM one. I found an OEM 460 cylinder and piston and that will be going on it in the future.
I have a few spare 372 carbs if you want I’ll mail you oneAn Echo 590 with an aftermarket Ms460 cylinder and a 372 carb, it runs good and was holding 12,700 RPM in the cut but I can't seem to get this crap AM carb to tune so I'm looking for a good OEM one. I found an OEM 460 cylinder and piston and that will be going on it in the future.
It's a Zama knock off.I know this sounds crazy ,but are you using the walbro or tilly knock off ?
That's awesome! I'll send you a PM.I have a few spare 372 carbs if you want I’ll mail you one
I've had trouble with that one but not the other, could have been dumb luck though.It's a Zama knock off.
Yea, it's like half the time you end up with a bad one. Everyone I've had a problem with has been on the low side.I've had trouble with that one but not the other, could have been dumb luck though.
That makes sense though, low side is gonna be harder to machine, where as high just has to dump fuel.Yea, it's like half the time you end up with a bad one. Everyone I've had a problem with has been on the low side.
I’m an idiot.......you’re an idiot!Seems to be an Echo in here.
I heard nobody watches your vids. That 394 sure looks like it wants it. Glad you found another one Pat.My personal 394 24” 8t just got it together after porting and machining. Still going to do some tweaks to it but at least I have a good idea what it likes.
I’m really glad I found another one also. This one I’ll keep foreverI heard nobody watches your vids. That 394 sure looks like it wants it. Glad you found another one Pat.
Yeah, I didn't like the zama knockoff I had either. It was just weird. It wouldnt even 4 stroke to 12k with that 50mm oe before I modded it and it had a weird low end stumble, almost like a rich stumbkeIt's a Zama knock off.
The one I have on the other 590 with the 440 cylinder works but there's very little adjustment on the low, in a 1/8 of a turn on the low screw you go from to very lean to to very rich.Yeah, I didn't like the zama knockoff I had either. It was just weird. It wouldnt even 4 stroke to 12k with that 50mm oe before I modded it and it had a weird low end stumble, almost like a rich stumbke
