Saw video thread
Chainsaw Jim
Con Artist LLC
1:21 AM
Springfield Oregon
I popped my noodle cherry on this log so I'll always remember it as a special moment in my life lol...even though that damn chain catcher ended up being a turd in the punch bowl.
54" cannon. It oiled the chain very well and the links were wet up to the teeth which actually surprised me. It probably doesn't hurt that the chain is one of those older Stihl ones with the oil holes on every driver.
Happy 4th of July!!!
Isaac
4:21 AM
Concord, NC
Once you ran all of them you wouldn't run the 390 anymore, it's a heavy pig.
I think a strong ported 395 will be very hard to out cut but the 661 vibes less and is no slouch especially with a long bar.
When I cut down I use my 395,once your use to how it cuts you won't carry anything else.
I really appreciate this post. I've been struggling with deciding on which of these three saws I'm going to buy next.
4:21 AM
I thought that was the 390 for a minute. 576 is a fat pig for 74cc but has torque.
jmssaws
Banneded
3:21 AM
Here's a 660 that i built for the mills logging crew,they run a bunch of 660's and they like them like this,machine work only and a muffler mod. No ignition advance or grinding of any kind.
CR500
4:21 AM
Western NY
Seems like a good recipe for a saw that gets ran by many operators and is ran on 50:1 ( a little more room for error I suppose )
If it was a personal saw for one guy I would expect a little grinding lol.
BTW Jason, are you short an 8 pin sprocket and gained a 7?
I've been running the 661 right out of the box with an 8 pin lol She got worked hard today removing a seasoned 30" cherry tree that had a heavy lean. I was shocked when I went to put on a different chain to see that it had a 8 pin sprocket after the tree was on the ground. Had some good torque with the 8 even, can not wait to try it out with a 7.
Sent from my non internal combustion device.
jmssaws
Banneded
3:21 AM
I cut a little timber with that 661 with 7pin and stripped drivers off the chain,I hadn't done that before, I switched to a 8pin after that. I probably have a 100 sprockets and most of the time the saw goes home with a new 8pin.
The 660 is a fallers saw that only one man runs,they are worked very hard and widening a port puts stress on things and these saws don't need any help in that department. They all get a 288 piston and machine work to make it fit and the muffler opened up and that's how they like them. The stronger they get they loose some usability in the timber.
CR500
4:21 AM
Western NY
Stripped drivers???
WTF lol
stihlman441
6:21 PM
near Geelong Australia
I would like to see a pic of that chain with missing drivers.
jmssaws
Banneded
3:21 AM
Can you explain this?
Boring and notching and trying to hit you marks is easier to do with a saw that isn't extremely fast at least I find it easier with a smooth and lower rpm saw like the 661 of CR500's. I don't cut down much anymore but when I do I always grab a mostly stock saw,my mild ported 395 is my favorite falling saw.
paragonbuilder
4:21 AM
Norwich, CT
Makes sense
