Saw video thread
Crocky28
9:36 AM
Scotland
I found gutting the tank vent gives them more “breathing room” for fuel too. Learned it from @Mastermind
Cool. Not tried that before. I’ll give it a go. I have a mark 2 550 to do, that’s my own saw. Might try it on that.
4:36 AM
How much do you gut them? Just remove all the internal?
I take the vent off the saw (it pulls off with pliers easily after the rubber line is taken off) and from the long end I push out the guts with a wire (or any long thin piece of metal that fits in the hole will work). I remove the white piece and the rubber piece. I reinstall the two sintered filters (large silver one and the small copper one). I reinstall it with a little dirko around the outside sealing area. B974D321-EBE5-4474-90C3-9D64B41D7ECE.jpeg I find it makes a difference on a ported 572, the stock vent seems to choke it in my experiences. A stock or muffler modded saw I would just leave it alone.
Crocky28
9:36 AM
Scotland
I take the vent off the saw (it pulls off with pliers easily after the rubber line is taken off) and from the long end I push out the guts with a wire (or any long thin piece of metal that fits in the hole will work). I remove the white piece and the rubber piece. I reinstall the two sintered filters (large silver one and the small copper one). I reinstall it with a little dirko around the outside sealing area. View attachment 331329 I find it makes a difference on a ported 572, the stock vent seems to choke it in my experiences. A stock or muffler modded saw I would just leave it alone.
Nice one, I’ll try it. You done it on any other auto tunes or just the 572?
pbillyi69
1:36 AM
USA
he said he replaced the sprocket because the other one was worn out. i know its a 7 pin and just assume its 3/8
Crocky28
9:36 AM
Scotland
357xp. The wind messes with the mic on the phone so it sounds a bit weird. Also four strokes a bit in the cut but if I leaned it out it’s max revs were 16400 I’m not ok with that [emoji23]
PA Dan
FYD
4:36 AM
White Oak PA
Make that chain more aggressive!
Crocky28
9:36 AM
Scotland
Yeah I’m thinking about getting a square grinder. No one doing it over here yet. That’s just Stihl RS straight out the box. It’s only done a few cuts.
