Saw video thread
Redfin
Meh...
3:11 AM
Central Pa
Would you be so kind as to point out what your tuning problem is? Because it sounds like it's pretty dialed in. The chain sucks, but that saw really cuts.
File the side of your rakers to vertical and those chips will stop grabbing your chain like that.
I opened the venturi on this carb. It was flooding so I increased the pop off a tad. I still think it needs some more. The high doesnt tune like I think it should.
As far as the chain, It doesnt suck, its the bar. I closed the rails before I made that vid. I have one of two issues, either the chain wasnt tight enough or there are places on the bar that are a bit to tight for the drivers. I need to sort it.
jmssaws
Banneded
2:11 AM
Got a stock carb to try?
Most of the carbs I grind on loose some tunability
